kaliinva
Apr 24, 2020Guide
R7000 reboots every 2 hours
My R7000 reboots randomly every few hours. I am unsure if this is a hardware or firmware issue. I have completed the reboot and reload multiple times but it keeps coming back randomly. The router i...
- Apr 30, 2020
Been going strong for the week. Looks like this may be the best resolution.
Apr 24, 2020Guru - Experienced User
1. try installing firmware version 1.0.9.42, factory reset it and manually re-install it
- kaliinvaApr 24, 2020Guide
Worked for 5 hours then rebooted again. Suggestions?
- plemansApr 25, 2020Guru - Experienced User
If its only a couple months old, I'd start an rma with netgear. Here's why
1. your on the most stable version of the firmware
2. you could check for hardware fixes but it might void your warranty.
- TrojanbroncoApr 25, 2020Aspirant
Any update on your situation? I'm having the same issue. Usually only happens at night when my kid is on his xbox and i'm streaming on netflix.
