br0107
Mar 29, 2020Aspirant
R7000 Remote Management Option not showing up under setup
I have an R7000 Nighthawk router and want to disable remote access. According to the router manual you select Advanced - Setup -Remote Management. When I go to Setup all I see is internet, wireles...
- Mar 30, 2020
> [...] can't find remote management. [...]
Hmmm. It was there at ".42".
> V1.0.9.88_10.2.88
I'd been avoiding that version for other reasons. Now you've
discovered another.Apparently, someone with too much idle time renamed the menu item to
ADVANCED > Advanced Setup > Web Services ManagementWhen you get there, the page title is still "Remote Management", if
that's any comfort. Perhaps the best approach would be to think of it
as, "Whatever's below 'Static Routes'".The latest R7000 User Manual ("January 2019") still says "Remote
Management". And for extra "clarity", "Remote Access".
> Great design, isn't it?More proof (as if any were needed) that no design is so poor that it
can't be made worse.
br0107
Mar 30, 2020Aspirant
Thanks for the help. I changed the selection to Advanced > Advanced Setup but there is not a remote management option there. There are 13 options in the list but no remote management. I have looked at every category under Basic and Advanced and can't find remote management. Any other ideas?
antinode
Mar 30, 2020Guru
> V1.0.9.88_10.2.88
discovered another.
- br0107Apr 01, 2020Aspirant
Thanks for the help. Remote Management was under Web Services Management as you pointed out.
