Rinobruno
Oct 08, 2021Aspirant
R7000 repeater collegato a TIM HUB
Ciao a tutti, volevo sapere se qualcuno è riuscito a collegare il R7000 come repeater con il router AGHP fornito da TIM. Ho provato a seguire mille guide e tutorial ma non ne vuol sapere di funzionar...
Oct 08, 2021Guru - Experienced User
In inglese per favore
- RinobrunoOct 08, 2021Aspirant
translate by google ;)
Hi everyone, I wanted to know if anyone managed to connect the R7000 as a repeater with the AGHP router provided by TIM.
I tried to follow a thousand guides and tutorials but it does not want to know that it works,
I see the Netgear-5G network but it does not connect to the internet. Advice? A thousand thanks Rino- FURRYe38Oct 08, 2021Guru - Experienced User
This should help you:
https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-router
yes thanks,
I've seen it before but it doesn't work. Could it be that my router does not have the bridge mode?
