Rinobruno
Oct 08, 2021Aspirant
R7000 repeater collegato a TIM HUB
Ciao a tutti, volevo sapere se qualcuno è riuscito a collegare il R7000 come repeater con il router AGHP fornito da TIM. Ho provato a seguire mille guide e tutorial ma non ne vuol sapere di funzionar...
Rinobruno
translate by google ;)
Hi everyone, I wanted to know if anyone managed to connect the R7000 as a repeater with the AGHP router provided by TIM.
I tried to follow a thousand guides and tutorials but it does not want to know that it works,
I see the Netgear-5G network but it does not connect to the internet. Advice? A thousand thanks Rino
Oct 08, 2021Guru - Experienced User
This should help you:
https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-router
- RinobrunoOct 08, 2021Aspirant
yes thanks,
I've seen it before but it doesn't work. Could it be that my router does not have the bridge mode?- FURRYe38Oct 08, 2021Guru - Experienced User
Now I can't remember, been a while since I looked at my R7000. I know the 7 series of routers has default router mode and AP mode. Some like my 7800 only have the additional wireless bridge mode, no repeater mode.
If you don't see Repeater mode on the R7000 web page then there would be Wireless Bridge mode along with Router and AP mode.
What 3 options do you see under the Advanced tab/Advanced Settings/Router mode page?
- sktn77aOct 09, 2021Virtuoso
The R7000 certainly can be set up as a repeater. Go into the web interface,
Advanced,
Advanced Steup
Router/AP/Bridge/Repeat
Choose Repeater.
