Jezzer
Jul 28, 2019Aspirant
R7000 Replacing a Tilgin router But No Internet Connection Detected
Hi all Just bought a R7000 Nighthawk AC1900 Smart WiFi router and tried to set it up, replacing a Tilgin router which still works The internet light is still orange on the Nighthawk, no matter ...
- Jul 28, 2019
I assume you just removed the old router and put the R7000 in its place, basically just connecting it to the modem? If so, you must power both off, modem and router. The modem needs to be 'reset'. That is seeing what is attached to it. Easy to do, when powered off it 'forgets' So with both off and disconnected from each other, power up the modem and wait for it to fully come up. Then do the same by plugging in the router and turning it on.
That should fix it. If not, you might need to contact your ISP? Possible they have some setting that needs to be changed?
Jezzer
Hi
Thanks so much for the swift response!
I did reset the modem to no avail!
I will take your advice and live call my ISP provider while I work on it again tomorrow morning
Many thanks for your help
Jez
Jez
IrvSp
Jul 28, 2019Master
Sorry it didn't fix it?
Were you able to access the Router? If you are using a wireless device and the Mobile Nighthawk app you can't, it requires Internet Access. However if you have a device with a BROWSER you can reach the Router and LOGIN (using Router IP Address or ROUTERLOGIN.NET as the URL). Once logged in you might need to do some modifying of the Internet settings if your ISP requires you to LOGIN? Only other thing I can think of?
Can you use a wired connection to the modem? Does it work? If it does, could be a cable problem or even a damaged socket?
