IrvSp
Jan 21, 2016Master
R7000, Reset button doesn't?
I'm on Firmware Version V1.0.4.30_1.1.67. Any other version above this gave me some wireless problems. Yesterday the 5Ghz channel dropped, well it really didn't, it was there but the PC using AC ...
- Retired_MemberJan 21, 2016
you can send a test e-mail from the log menu
netwrks
Jan 21, 2016Master
Depress the reset button until the power light flashes, then let go. It should reboot..Or reset via router software. You have two options..
IrvSp
Jan 21, 2016Master
netwrks wrote:Depress the reset button until the power light flashes, then let go. It should reboot..Or reset via router software. You have two options..
That is what I did... and nothing was reset. It seems there are 2 distinct modes here... well 3. A power button recycle (off and back on), the reset button that seems to do the same as the power button recycle without turning the router physically off (same as reboot via the GUI), and an erase via the GUI?
If I have further problems I'll try the GUI erase I guess?
