IrvSp
Jan 21, 2016Master
R7000, Reset button doesn't?
I'm on Firmware Version V1.0.4.30_1.1.67. Any other version above this gave me some wireless problems. Yesterday the 5Ghz channel dropped, well it really didn't, it was there but the PC using AC ...
- Retired_MemberJan 21, 2016
you can send a test e-mail from the log menu
IrvSp
Jan 21, 2016Master
Ugh, figured it out.... flash IS broken...
Saw this thread ==> https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Nighthawk-R7000-not-emailing-log/td-p/984826/page/2 and in it:
2015-10-21 08:18 AM
Hi it may not work well with 4.30 firmware.
So looked on-line in support on how to configure since the HELP is blank and found this page, http://kb.netgear.com/app/answers/detail/a_id/29833. Interesting picture...
Hmm, notice I had only 1 line, 'Your Outgoing Mail Server'. So I entered my data like above. Still failed? So I reversed the 2 lines with the SMTP on the bottom. That worked... or at least it took it. I'll know tomorrow.
Broken Flash it seems...
Retired_Member
Jan 21, 2016you can send a test e-mail from the log menu
