TessAmple
Nov 24, 2023Follower
R7000 Router - Unable to connect to routers network during setup
Hi, Hoping someone can help provide us a solution. We just brought home the R7000 Netgear Nighthawk router and are going through the setup instructions step-by-step however, when trying to connect to ...
Nov 26, 2023Guru - Experienced User
the manual do show that but when you check all the ddwrpt/open-wrt wiki's it shows release data 2013.
And the reviews from release for it at from 2013.
Maybe they did a big update to all the manual in 2017 or something.
michaelkenward
That would be a turn up for the books.
There was another manual in 2019.
There were some big changes in that window, when they implemented the Nighthawk apps and releases some major firmware updates.
The most reliable local check should probably be to look at the first firmware release. (Ignore the readme, which can get updated.) The chk file is dated 2013-08-12.
Certainly a while before 2017.
