Fademan
Oct 15, 2021Tutor
R7000 Router connectivity and setup problem
Hi there, I just recently pulled out my old R7000 router from storage in an attempt to deploy it in a new network. Because I couldn't remember how it was configured, I used the "Reset" toggle at th...
Oct 16, 2021Guru - Experienced User
Have you tried resetting it again? Push and hold reset for 7-15 seconds while powered on?
If that doesn't help, you can try recoverying it.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Fademan
Oct 16, 2021Tutor
plemans wrote:Have you tried resetting it again? Push and hold reset for 7-15 seconds while powered on?
- I connect a laptop to the router.
- Disable wifi from the laptop
- Change the ethernet settings per the guide
- Connect the laptop to LAN1 , LAN2, LAN3, or LAN4 ports
- The laptop reports "media disconnected", and none of the port lights up on the router.
- Connecting the laptop to the WAN port
- The laptop reports "Unidentified network" and the internet light on the router goes orange.
- However, attempting to ping 192.168.1.1 reads destination unreachable
Running the tftp command (using either LAN or WAN ports) gives me "Connect request failed".
However, if I boot cycle the router, the LAN port/s light up when booting up, then the light turns off once its up and running.
