kp1738's avatar
kp1738
R7000 Router EXTREMELY SLOW INTERNET
I'm having trouble figuring out why I'm getting EXTREMELY SLOW internet speeds through my Nighthawk R7000.  Internet was buggy so I decided to call Spectrum to see why the internet was slow.  They ra...
  • kp1738's avatar
    kp1738
    Apr 22, 2020
    Thanks!  That was actually part of what I meant when I said I had turned off the modem's wifi.  The tech guy had me go into the settings and disable its routing functions and plug the ethernet cable from my router into the SBG's port 1 so that it would only act as a modem.
    Firmware is currently on V1.0.9.88
    My brother fixed the problem.  He changed the router's MAC address to default and disabled QOS.  Now getting 200+ mbps on my computer and 120+ mbps on my PS4!
