lookiesh
Mar 26, 2022Follower
R7000 router is very unstable and need a help!
Hello, I have R7000 and used it at the office then I relocated to different state and now trying to use it at home. I had another router (EERO) at home, but the wifi speed was not satisfied so ...
Mar 26, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or Circle enabled on the router?
- wcalifasMar 26, 2022Prodigy
when you say unstable are you saying that the wifi disconnects or how is it unstable?
