lookiesh
Mar 26, 2022Follower
R7000 router is very unstable and need a help!
Hello, I have R7000 and used it at the office then I relocated to different state and now trying to use it at home. I had another router (EERO) at home, but the wifi speed was not satisfied so ...
Mar 26, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor or Circle enabled on the router?
wcalifas
Mar 26, 2022Prodigy
when you say unstable are you saying that the wifi disconnects or how is it unstable?
