Jkeyman
Jul 28, 2017Aspirant
R7000 router no stable wifi and no upload
Hi, Since yesterday i have the R7000 router connected to my modem from my ISP provider. I put the modem in DMZ and all looks fine. But i noticed during speed tests at Oklaa that i have nu upload now...
- Aug 04, 2017
Hi Jkeyman,
If you connect the device to the modem, will you get a stable connection? Make sure the modem is not a modem/router. If it is a modem/router as one, try to set it to modem only.
Jkeyman
I will try. But I put in DMZ because my ps4 needs a Nat type 2 connection. Before I put the modem in dmz I had Nat type 3.
Jkeyman
Jul 29, 2017Aspirant
I tried turning of the dmz but that did not help.
- JamesGLAug 04, 2017NETGEAR Employee Retired
Hi Jkeyman,
- JamesGLAug 07, 2017NETGEAR Employee Retired
Hi Jkeyman,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
