HTW2020
Sep 19, 2021Aspirant
R7000 router not recognizing network
I have tried rebooting several time, however, the network does not show up on my devices
HTW2020
Not sure about the firmware. The modem is Arris TM1602. It appears that the router is not broadcasting. Wired does work. When trying to select a WiFi network on my phone, it does not show up. There are other networks showing up from neighbors
Sep 19, 2021Guru - Experienced User
Is the wifi led's on?
Did you try pushing the wifi on/off button for 2 seconds?
