Bruiser972
Mar 30, 2023Aspirant
R7000 Router not showing wired device
Hi - I've recently plugged in a Synology NAS device into the back of my R7000 wifi router as the NAS doesn't have wifi. On a previous network, I could see the NAS and interact with it, but on the R70...
- Mar 30, 2023
Be sure the networking on the NAS is set for auto obtain IP addressing. Check with the mfr of this NAS box for help and support regarding this. Possible a reset on the NAS maybe needed. Check first.
Be sure your using a good quality LAN cable between the router and NAS box.
Power OFF the NAX and router for 30 seconds then back ON with the router then NAS. NAS should appear getting an IP address on the routers web page.
Bruiser972 wrote:
Hi
I'm looking directly in the router firmware (via 192.168.1.1) and also on the Nighthawk app.
Firmware version V1.0.7.6_1.1.99
Modem is a Netgear CM1000. It only has one LAN port which is used to connect the wifi router. I have plugged the NAS into the WiFI router as it has a bank on LAN ports.
I hope this helps.
michaelkenward
Mar 30, 2023Guru - Experienced User
Bruiser972 wrote:
On a previous network, I could see the NAS and interact with it, but on the R7000 no wired devices are showing and the Synology Assistant cannot find the NAS.
Where are you looking and what with?
Windows is very good at hiding network devices.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
For better advice on your router, try here:
Nighthawk Wi-Fi 5 (AC) Routers - NETGEAR Communities
- Bruiser972Mar 30, 2023Aspirant
Hi
I hope this helps.
- michaelkenwardMar 30, 2023Guru - Experienced User
Looking where? Attached devices?
What about Windows networks?
This is a good alternative for Windows and Macs:
genie | Product | Support | NETGEAR
Be warned that the genie installation file is wrapped up in a RAR archive that you have to decompress and install.
Netgear is trying to kill this useful utility.
I've now got this utility, but still not showing any wired devices - all are wifi.
I'll try the reboot options suggested by others
Seriously ancient. There have been a couple of dozen since then.
R7000 Firmware Version 1.0.11.136 | Answer | NETGEAR Support
Thanks - now updated to V1.0.11.136_10.2.120 which is the latest I could find.
- FURRYe38Mar 30, 2023Guru - Experienced User
Bruiser972 wrote:
Hi
I hope this helps.
- Bruiser972Mar 31, 2023Aspirant
The rebooting worked!
Thank you!! 🙂
