artiste1212's avatar
artiste1212
R7000 router sometimes disallows wifi connections
I'm using the R7000 AC1900 router with the most current firmware version. My desktop computer is connected via cable, while my phone and laptops are connected through wi-fi. Periodically (approximately 1 or 2 times per month), the router prevents the other devices from accessing the internet via wi-fi, but still allows my desktop wired connection. The devices show as being connected to the router via wi-fi but no internet access -- while internet access does work for my desktop. How can I prevent this from happening?
  • plemans's avatar
    What actual firmware version are you on? The r7000 regularly says "up to date" and isn't.
    What modem/gateway is it connected to?
    • artiste1212's avatar
      artiste1212
      Thanks. It's firmware version  V1.0.11.126_10.2.112, attached to a Motorola E31U2V1 modem.
      • Portwey84's avatar
        Portwey84
        Virtuoso
        artiste1212  It might be worth just giving your router a quick reboot to see it if resolves the issue. Easily done by using the Nighthawk App.
