cool_guy
Jun 29, 2024Aspirant
R7000 Router
I have R7000 router. My ISP upgraded my speed to 500Mpbs and I get about 450Mbps when I connect my PC directly to the modem. But, when I connect my PC to the router, I only get about 200-210Mpbs. Are...
Jun 30, 2024Guru - Experienced User
what modem do you have?
what firmware is on the R7000.
the R7000 is over a decade old. It took some special settings to hit gigabit speeds over wired with it when it came out. Make sure access control, traffic monitoring, parental controls, and qos are all disabled. If there were disabled, try a factory reset and reinstall. Make sure those aren't enabled during the install. then test the wired speed
- michaelkenwardJun 30, 2024Guru - Experienced User
It predates the time when ISPs offered gigabit Internet.
Back then Netgear still sold routers with LAN ports stuck at 100 Mbps.
