sktn77a
Feb 25, 2025Virtuoso
R7000 security settings keep being requested
I have 4 Netgear R7000 routers at different locations. I just updated one of them to the latest firmware version (1.0.12.216) and am having an issue I don't have with any of the others. When loggin...
Feb 25, 2025Guru - Experienced User
Possible something got messed up on the FW update. Best to reset the router and setup from scratch and during the setup wizard, input those security values. Be sure to write down this important information for safe keeping should something happen.
sktn77a
Thanks. I've reset the router a couple of times already and gone through the process again but it's still doing the same thing (?)
- FURRYe38Feb 25, 2025Guru - Experienced User
What browser are you using? Happens with a different browser? Try Firefox, MS Edge or Opera?
Be sure to clear out all browser caches and any saved PW profiles with in the browser as well.
- sktn77aFeb 25, 2025Virtuoso
Good idea. I'll try Edge and clear out the caches.
- sktn77aFeb 28, 2025Virtuoso
Nope, clearing the cache and using Edge didn't help. May not matter but the firmware update didn't proceed automatically from the configuration page - I had to download the firmware file first and update manually.
