Vine-Leaf's avatar
Vine-Leaf
R7000 sees USB 3.0 portable drive not 8TB external drive
This router has both a USB 2 and 3  ports. I plugged a USB 3.0 WD Passport 3 TB drive into the USB 3.0 port. The drive spins up and the indicator light goes on. This drive is formatted NTFS   I plu...
  • Vine-Leaf's avatar
    Vine-Leaf
    Jan 21, 2020
    I determined that neither of the large WD drives worked. I looked at the netgear support site for the R7000 (https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE)
    Based on this I tried the Seagate - Backup Plus Hub 8TB External USB 3.0 (SRD0PV1)  Plugged it in and after a while readyshare found it and made it available.
    I will use my WD drive as a backup for the shared drive as an extra precaution.
    I used the 3.0 front facing USB port. I plan to see if the drive will also connect from the USB 2 port on the back.
