Vine-Leaf
Jan 03, 2020Aspirant
R7000 sees USB 3.0 portable drive not 8TB external drive
This router has both a USB 2 and 3 ports. I plugged a USB 3.0 WD Passport 3 TB drive into the USB 3.0 port. The drive spins up and the indicator light goes on. This drive is formatted NTFS I plu...
- Jan 21, 2020
I determined that neither of the large WD drives worked. I looked at the netgear support site for the R7000 (https://kb.netgear.com/18985/Will-my-USB-drive-work-with-ReadySHARE)
Based on this I tried the Seagate - Backup Plus Hub 8TB External USB 3.0 (SRD0PV1) Plugged it in and after a while readyshare found it and made it available.
I will use my WD drive as a backup for the shared drive as an extra precaution.
I used the 3.0 front facing USB port. I plan to see if the drive will also connect from the USB 2 port on the back.
michaelkenward
Jan 11, 2020Guru - Experienced User
Vine-Leaf wrote:
I am thinking that the Router / Readyshare initially examines the drive and produces some sort of index. I am not claiming to know anyting about how this works.
It will of you have DLNA active.
Nothing massive though. 1.14 GB on my half full 4TB drive with ~750GB of music.
Vine-Leaf
Jan 21, 2020Aspirant
