mc510
Mar 30, 2019Guide
R7000 sees USB flash drive; does not see USB hard drive
I plug a no-name 8GB USB 2.0 flash drive into the USB 2.0 port, and the R7000 recognizes it immediately.
I plug my 500 GB WD My Book Essentials 2.0 USB 2.0 hard drive into the same port, and the ro...
- Mar 31, 2019
That should work as it is powered by its own power supply.
Three possible things to look at:
- The cable, either slightly damaged or the port itself.
- Does it work in the USB 3.0 port? If it does, it could be the firmware, many people have a variety of problems with V1.0.9.64_10.2.64.
- Try running CHKDSK on it on the PC (it should ask you to do this when plugged in if it is discovered to have a problem though).
IrvSp
Mar 31, 2019Master
