johnmsch
Oct 17, 2022Aspirant
R7000 Send Logs Via Comcast SMTP
My R7000 is running v1.0.9.88_10.2.88 and I can't get it to send the logs using Comcast SMTP. I found an old post about this here and wanted to see if there was any updates on this situation, especi...
Kitsap
Oct 17, 2022Master
Yes, everyday.
The settings in your router appear to be correct. If you go to Advanced -> Administration -> Logs and click on Send Log at the top, whatever error you get should show up in the log.
Within your Comcast e-mail settings, use a web browser and log in to your Comcast web mail and click on settings in the upper right hand corner, check on the Security settings and make sure Third Party Access is allowed. See attached.
johnmsch wrote:
Has anyone been able to get this router to send the logs via Comcast SMTP?
