Pisklink
Feb 25, 2016Aspirant
R7000 Slow download speed (wired and wireless)
I have the R7000 for about a year now and originally I had the correct download and upload speeds that corresponds with my ISP rates. At this moment my ISP (cable) delivers 120 Mbps down and 12 Mbps...
- Mar 06, 2016
The RMA indeed resolved the issue.
P.S. I accidently marked the answer of Tarund as the answer to my question.
Can you please remove that?
JamesGL
Mar 05, 2016NETGEAR Employee Retired
Hi Pisklink,
Provide us update if RMA resolves your concern.
Pisklink
Mar 06, 2016Aspirant
- JamesGLMar 07, 2016NETGEAR Employee Retired
Hi Pisklink,
Glad to know it works now. The post is no longer tagged as accepted solution. I will tagged your reply as the accepted solution.
