Pisklink
Feb 25, 2016Aspirant
R7000 Slow download speed (wired and wireless)
I have the R7000 for about a year now and originally I had the correct download and upload speeds that corresponds with my ISP rates. At this moment my ISP (cable) delivers 120 Mbps down and 12 Mbps...
- Mar 06, 2016
The RMA indeed resolved the issue.
P.S. I accidently marked the answer of Tarund as the answer to my question.
Can you please remove that?
Fitz11
Mar 08, 2016Tutor
What's RMA. I'm having similar issues
Pisklink
Mar 08, 2016Aspirant
RMA = Return Merchandise Authorization
It means that Netgear allows you to send you product back and get it repaired or replaced by a similar product.
But please don't send you product back without having received a RMA number from Netgear.
You should formally get a RMA number from Netgear before returning your product.
