wimkt
Feb 01, 2018Tutor
R7000 slow download speed
Hi, My ISP upraded my cable connection to 500mbps. As I connect directly to the modem I recieve around 500mbps, when I connect through my R7000 router the speeds drops to around 250mbps. The tech...
- Feb 01, 2018
I enabled QoS, updated the data base, ran a speed test, disabled QoS, rebooted my router.
Unfortunatly still the same testresults, around 350mbps
aabshire
Feb 01, 2018Apprentice
Wired or wireless connection to the router?
wrote:Hi,
My ISP upraded my cable connection to 500mbps. As I connect directly to the modem I recieve around 500mbps, when I connect through my R7000 router the speeds drops to around 250mbps. The technician from my ISP says the problem is the router (wich seems obvious).
I find alot of posts from other users with the same problem. I don't have the time to search every post related to this problem to find the solution. So my question is: what is the most up-to-date solution to this problem ?
Thank you
wimkt
Feb 01, 2018Tutor
We speedtested with a wired connection.
The download speed drops with 50% (from 500mbps (modem) to 250mbs(router)). We even installed a new cable, wich eventually did not solve the problem;
Upload speed stays the same
Thank you
