wimkt
Feb 01, 2018Tutor
R7000 slow download speed
Hi, My ISP upraded my cable connection to 500mbps. As I connect directly to the modem I recieve around 500mbps, when I connect through my R7000 router the speeds drops to around 250mbps. The tech...
- Feb 01, 2018
I enabled QoS, updated the data base, ran a speed test, disabled QoS, rebooted my router.
Unfortunatly still the same testresults, around 350mbps
wimkt
Feb 01, 2018Tutor
We speedtested with a wired connection.
The download speed drops with 50% (from 500mbps (modem) to 250mbs(router)). We even installed a new cable, wich eventually did not solve the problem;
Upload speed stays the same
Thank you
aabshire
Feb 01, 2018Apprentice
I get 420 MB from my 400 MB service with my R7000. What firmware version are you on? Do you have another pc/laptop you can test with to compare?
wrote:We speedtested with a wired connection.
Thank you
- wimktFeb 01, 2018Tutor
I tested with my pc, mac mini and laptop. All 3 around the same testresults (250mbps - 280mbps).
I haven't done anything else other than installing a new cable.
I have never tested before the cable upgrade, but I was a little disappointed to see a result of 250mbps as my modem provides 500mbps.
I'm on the latest firmware: V1.0.9.18_1.2.27
- aabshireFeb 01, 2018Apprentice
The latest firmware is: V1.0.9.26_10.2.31 for the R7000
https://kb.netgear.com/000053870/R7000-Firmware-Version-1-0-9-26-Hot-Fix
Also you are connecting via a ethernet card/connection of the PC, mac mini & laptop and not a usb/ethernet connection correct? (USB 2.0 is limited to 250-300 MB)- wimktFeb 01, 2018Tutor
Oh, I checked the firmware but the r7000 says there are no updates. I will manually install the hotfix.
I am connecting via the ethernet card/connection.
I will reply back after the hotfix
