wimkt
Feb 01, 2018Tutor
R7000 slow download speed
Hi, My ISP upraded my cable connection to 500mbps. As I connect directly to the modem I recieve around 500mbps, when I connect through my R7000 router the speeds drops to around 250mbps. The tech...
- Feb 01, 2018
I enabled QoS, updated the data base, ran a speed test, disabled QoS, rebooted my router.
Unfortunatly still the same testresults, around 350mbps
wimkt
Feb 01, 2018Tutor
One question:
Is there any order in enabling/disabling and updating the QoS database ?
aabshire
Feb 01, 2018Apprentice
No you can actually update the databased before you apply. You have to click "Enable QoS" in order for the Update Database to show up. Update it. Apply the Enable, once finished, uncheck "Enable QoS" and Apply again
