JoeBell
Jun 04, 2021Aspirant
R7000 Slow Download Speed
Spectrum recently upgraded my internet download speed to 200. When I do a direct ethernet connection to the modum, I'm getting 200. When I go through the R7000|AC1900 router (hardwire, not wifi), I...
- Jun 05, 2021
plemans wrote:
3. did you ever try a factory reset and reinstall?
This is important. If an ISP changes the service, then the settings may be different.
It isn't just the router that needs to change, so does the modem. They need to forget past settings or the router may still have details picked up from the slower service.
If the network changes, you can't just carry on regardless. You need to reboot the network:
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Jun 04, 2021Guru - Experienced User
a couple things you can try.
1. ensure you have either a good quality cat 5e cable or a cat6 cable. I've seen sketchy cat 5e cables not connect at gigabit speeds
2. what modem is it?
- michaelkenwardJun 05, 2021Guru - Experienced User
- JoeBellJun 05, 2021Aspirant
Did a hard reset and that fixed the issue. Download speed is now over 200. Thank you.
While re-entering all my passwords, etc. after the reset, I noticed my firmware version is at V1.0.9.88_10.2.88. I directed the app to look for a newer version and it returned that no newer version was found on the Netgear site. I found that hard to believe, so I checked the Netgear site and found numerous versions of firmware that are newer than mine. Should I manually download and install a newer version or leave well enough alone? If I should install a newer version, which one?
- michaelkenwardJun 06, 2021Guru - Experienced User
In theory, you should have the latest version of the firmware. That is to keep you up to date with security improvements as Netgear tries to block newly discovered vulnerabilities.
But in reality Netgear also uses updates to change the features available on some devices. In the case of the R7000 it has killed off some features so that it can make room for fee paying stuff like Circle and Armor.
It seems that they have already done this in your version:
Please note that starting with this firmware release (V1.0.9.88), iTunesServer, Kwilt Photosharing, Time Machine Backup, TiVo support for media sharing, and the Downloader feature (which was in beta) are no longer supported. If you want to continue using these features, do not update the firmware.
I would check the newer updates. If you are happy with what they promise/threaten I would update to the latest. But be prepared to backtrack if you have problems.
- dbshotgunnnJun 07, 2021Aspirant
V1.0.9.88_10.2.88
I'm having a similar issue, except my hardwired speed at my desktop is 224.67 mbps and my wife's laptop on wifi is around 36 mbps. All of my wifi around the house is slow, close and far from the router makes little differance. the best wifi speed i got, being six feet away from the router was 54 mbps. We first noticed it last night while watching netfix in the living room, a couple of times the picture quality got poor and pixelated. I tryed your reset (unplug everthing than plug back in) and my speed improved by 10 mbps, but still is no where near matching my wired connection.When i test the connection speed on my tv, it says 26mbps, but it has always read weird numbers. I can stream 1080p Youtube vids no problem, I think the Vizio is just trying to ping Mars when you do a connection test. Just where are my wifi speeds supposed to be in relation to my hardwired speeds?
- plemansJun 08, 2021Guru - Experienced User
dbshotgunnn Please start your own thread and we're happy to help
