okieopie
Dec 02, 2021Tutor
R7000 Slow Download Speeds with New Fiber Optic - Previously Fine
I just had fiber optic installed in my home but am having trouble with throughput on my router. Previously I had cable internet and would get speeds that were consistent with what I was getting from ...
- Dec 02, 2021
Try replacing the cable between modem/router. I've seen sketchy cables connect at gigabit on some devices and only 10/100mbps on others.
You can also check in the router if its connecting at gigabit.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Dec 02, 2021Guru - Experienced User
- okieopieDec 03, 2021Tutor
The Statistics show the WAN Status as 100M/Full - which I guess explains the slow slow connection. Is there a setting to change?
Just tried changing the CAT5 cable. Improved the speed immensely. Now getting 275 down. Thanks for your help.
- plemansDec 03, 2021Guru - Experienced User
I'd toss that other cable in the garbage and not back in the "cable bin".
Like I said, I've seen some cables that work fine on some devices at gigabit but then on others, will only connect at 10/100mbps speeds. Tends to be sketchy cables.
