corygehr's avatar
corygehr
R7000 Slow Internet over WiFi
I seem to be having internet speed issues with my R7000. When I watch Netflix on my Xbox One, I notice dropped frames a few times every minute. Sometimes, DNS lookups also fail the first time and I need to either resubmit the request or reboot the router. This only happens over WiFi, as all of my devices connected via Ethernet do not have these problems. Has anyone encountered this? Are there ways I can correct it?
Thanks.
  • VE6CGX's avatar
    VE6CGX
    Aug 05, 2015
    Hi,
    On 2.4MHz band, channel 1,6,11 are non-overlapping. I always tried to use one of these channels. On 5GHz
    I always used hi channels like 149/153, on R7000 this hi channels give better signal level. Don't use
    auto channel selection. Usually if signal level is better than 60dbm WiFi is stable. Playing with antenna
    and position of router can improve signal levels. Set antenna sticks like this   \  |  /, broad side should point to
    general direction of devices.(router front and back) That's what I did when I had R7000.
    • corygehr's avatar
      corygehr
      V1.0.4.30_1.1.67, which appears to be the latest.
  • For steady WiFi performance,  two factors to consider, 1. Decent signal level at device end.
    2. Channel selection of minimun interference. To survey your WiFi environment, do you use
         utility such as Acrylic or inSSIDer(V4 is needed to check 5GHz ban)?
    • corygehr's avatar
      corygehr
      I can confirm over a Site Survey that I'm the only device using channel 8 over the 2.4GHz band - not sure about 5GHz as my phone and Xbox are the only devices that can use that. Still, it's on Auto which could be part of the issue? The devices are less than 20 feet apart with a plaster wall in the way, so signal is 100%.
      Network topology is simple - I have a fiber connection that terminates in my wall (it's an apartment complex) and from the patch panel there's a run to a jack in my den that connects to the R7000. After that, nothing else is really in the way. At peak I'll have a client bridge via DD-WRT (using the 2.4GHz network), a desktop attached to that, my laptop (hard-wired into the router), my Surface Pro, my Xbox One (5GHz), and my Windows Phone. However, the Surface is usually on standby and I've been having issues with the client bridge so the majority of the time it's just my phone, laptop, and Xbox that are actually pulling through the pipe. It's a 100Mbps line to the internet.
      • VE6CGX's avatar
        VE6CGX
        Master
        Hi,
