DarthWarduke
Dec 04, 2021Aspirant
R7000 slow speeds
Looking for advice. I have the R7000 and dealing with slow speeds. Have Xfinity service and tech was just here and tested as high as 1300Mbps coming in. Tested 751Mpbs at the Arris Surfboard Modem. B...
Dec 05, 2021Guru - Experienced User
How are you testing speeds from the router?
what device are you hardwiring in to test?
What site are you testing speeds on?
Are you using the built in speedtest or using a app/browser?
What arris modem is it?
DarthWarduke
Dec 05, 2021Aspirant
We tested speeds from the modem and from the router. The coax is coming in from outside to the router and then ethernet to the modem and then ethernet to the desktop.
The Arris model is the SB6190.
Sites I was testing on was in the router page, speedtest.net and speedtest.xfinity.com
The testing equipment used for testing was the Xfinity tech's gear.
- DarrenMDec 10, 2021Sr. NETGEAR Moderator
Have you made sure you have QOS disabled? Are you on the latest firmware?
DarrenM
- microchip8Dec 10, 2021Master
Testing speed within the router's GUI interface is almost never accurate. Use something like Ookla or other test site. Do note that since you have 1.3 Gbps package, you'll never reach it since the router is 1 Gbps
- DarthWardukeDec 10, 2021Aspirant
I understand that, the speed was tested "up to" 1.3 but my package is set to 600Mbps. Running the modem direct to tower via ethernet is 751Mbps but when I run through the router it's down to 180 - 200Mbps.
Yes I have the router on auto update and checked it was on the latest firmware. QOS is disabled.
- FURRYe38Dec 10, 2021Guru - Experienced User
Try a factory reset and setup from scratch. Don't enable QoS, Access Controls, Armor or Traffic Meter. I would power OFF the modem for 1 minute as well during the reset.
Test with a wired PC with the router and see.
