Claes_Bergefall's avatar
Dec 14, 2016
R7000 slow upload over wifi (android)
Hi
I recently switched my router to the R7000 connected to VDSL line via a Netgear DM200 modem (PPPoE). This all works just fine for most devices connected.
However, for some strange reason the upload speed over wifi for some devices are really bad.
- An iPhone and an iPad works just fine
- All computers running Windows works perfectly fine both wired and wireless
- All android devices fail. Download speed is fine but upload measures at 0.0 (compared to 2Mbps for everything else). Tested this on 2 samsung tablets, a kindle fire, a motorola phone and a sony phone. They're all the same and they all struggle to load certain sites or upload things. The only thing they have in common is that they all run Android in some form. This happens on both 2.4 and 5 Ghz (don't have any wired Android devices).
I've updated to the latest firmware (1.0.7.2) and did a factory reset afterwards, but that didn't help. In discussions for some other routers a few people suggested putting a switch between the modem and router, so I tried that as well without any luck. I even tried downgrading the firmware to some earlier version but that didn't make any difference.
If I plugin my old router (a TP-Link, still via the DM200 modem) everything is back to normal and works perfectly. My old router doesn't support AC or 5GHz wifi though so I would like to get the new one working.
That it only seems to affect Android devices feels really bizarre. I could understand if all wifi struggled, but laptops and apple devices works just fine.
I still have time left on the 90 days free support but I figured I try here first.
Any ideas? Something else I should try?
Thanks
  • Retired_Member's avatar
    Retired_Member
    Dec 15, 2016
    What settings did you use on the TP?
    Try FW 1.0.4.30
    Retired_Member
    Try FW 1.0.4.30
    • Claes_Bergefall's avatar
      Claes_Bergefall
      Tutor
      Settings on the TP are:
      PPPoE Always on
      MTU 1480
      Enable IGMP Proxy
      Echo request intervall 30 sec
      DNS Servers 8.8.8.8 and 8.8.4.4
      Rest is disabled/empty.
      Think the R7000 has the same settings but will double check and try the 1.0.4.30 FW this weekend.
      Thanks
        Retired_Member
        You're welcome,
        I don have any android to test with. How is the DM200 setup what mode are you using?
