BBMD
Feb 17, 2024Follower
R7000 slow wifi connection
I have an R7000 in AP mode connected by Cat6 cable to a ISP router with 1Gbps service. When I connect to the ISP router, wifi speeds are 200-300Mbps. Plugging the cat6 cable that comes from the ISP...
Feb 18, 2024Guru - Experienced User
Might be worth checking the wan port statistics to ensure its connecting at gigabit speeds.
The 90mbps on 5ghz makes me suspicious.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
