Peanut64
Nov 04, 2015Aspirant
R7000 slow wifi
I have the R7000 nighthawk wireless router. Im using Comcast for my internert. (their blast pro level) Using speedtest my hardwired PC computer download speed is 180mbps. My son with highspeed g...
- Nov 04, 2015
Yes, don't use auto channel. Use a Wi-Fi scanner like the one in the Netgear desktop Genie program, or Vistumbler or Acrylic WiFi to find the least congested Wi-Fi channel around you.
Better yet, connect to the 5 GHz network. 5 GHz has less range, but it's much faster than 2.4 GHz at close to moderate distances.
TheEther
Nov 04, 2015Guru
Make sure you use WPA2-PSK [AES] security, if possible. Try changing the Wi-Fi channel. Try connecting at 5 GHz. Remove or turn off any devices that could interfere with Wi-Fi, like baby monitors or microwave ovens.
What kind of wireless devices do you have? They may not be capable of running faster than 30 Mbps.
- Peanut64Nov 04, 2015Aspirant
Im using a brand new HP spectre laptop and a lenovo yoga plus samsung tablet and samsung smart TV.
I have 2.4 channel set to auto. Is that bad?
- TheEtherNov 04, 2015Guru
