Teledatax
Dec 26, 2021Aspirant
R7000 slow wired speed
I have a R7000 and recently upgraded to a CM1150v modem and there is a significant speed reduction using the router with the modem. A wired connection PC to modem is 600-700MB while the wired conn...
- Dec 27, 2021
plemans wrote:
I'd try manually updating over a wired connect and then after the update do a factory reset/reinstall because the firmware has changed a lot since the version you're on.You should also reset the router because you are asking it to connect to a new modem. So the R7000 has to forget any settings it picked up from your old modem.
And remember the other golden rule.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
Brandynn
Aug 13, 2022Aspirant
Hi, I am having the same problem. i am currently on Version V1.0.11.136. I have ATT Fiber 1Gbit Up/Down. In the netgear configuration settings speed test, speeds vary from 220mbps down and 20mbps up. I have The BGW-210 Modem and in its advanced configuration speeds get to 970 up/down and is also set to IP passthrough to the R7000 router with a dedicated AP for the wireless connections. R7000 handles all the wired connections and does not broadcast any SSID.
When ever someone downloads a small file it cripples the whole connection for others im not sure if thats normal. i have around 22 concurrent user with 5 of those Wired connections. peak 30 concurrent user.
Thanks for the help!
michaelkenward
Aug 14, 2022Guru - Experienced User
Brandynn wrote:
I have The BGW-210 Modem ....
Google suggests that this is a modem/router.
Solved: How do I setup bridge mode in the ARRIS BGW210-700 - NETGEAR Communities
