DESMO1198s
Oct 01, 2017Guide
R7000 SLOWS WAY DOWN with Firmware 1.0.9.10 went back to 1.0.9.6 problem solved. Hold off on update
Just updated the Firmware of my R7000 to the latest 1.0.9.10 from 1.0.9.6 and it cut my download speed from 178MBps on all my devices ( MacBook Pro, iPhone7, iPad Air2) to less than 80MBps. Full pow...
michaelkenward
Oct 02, 2017Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So a factory reset is the first thing to try if you have problems with new firmware.
First note down the settings – screen grabs can help here.
No guarantee that you wouldn't see the same problem, but a reset has solved similar issues in the past.
