DESMO1198s
Oct 01, 2017Guide
R7000 SLOWS WAY DOWN with Firmware 1.0.9.10 went back to 1.0.9.6 problem solved. Hold off on update
Just updated the Firmware of my R7000 to the latest 1.0.9.10 from 1.0.9.6 and it cut my download speed from 178MBps on all my devices ( MacBook Pro, iPhone7, iPad Air2) to less than 80MBps. Full pow...
jnysingh
Oct 02, 2017Aspirant
Same here! The download speed has dropped from 400 Mbits/s to 230 Mbits/s. After downgrading the firmware to 1.0.7.12 I got the best speed. Firmware 1.0.9.6 also gives a significant speed drop.
- michaelkenwardOct 02, 2017Guru - Experienced User
Did you "factory reset"?
This is important information in several ways. First it will help other users to decide to try it. Second it will make it harder for Netgear to ignore you.
