DESMO1198s
Oct 01, 2017Guide
R7000 SLOWS WAY DOWN with Firmware 1.0.9.10 went back to 1.0.9.6 problem solved. Hold off on update
Just updated the Firmware of my R7000 to the latest 1.0.9.10 from 1.0.9.6 and it cut my download speed from 178MBps on all my devices ( MacBook Pro, iPhone7, iPad Air2) to less than 80MBps. Full pow...
michaelkenward
Oct 03, 2017Guru - Experienced User
nsEra wrote:I've been having this issue since they released version "1.0.8.34". My internet is 1000Mbps Down - 50Mbps Up...
Manuals for some newer hardware recommend turning off QoS for Gbps connections, probably on the grounds that you don't need it at those speeds.
nsEra
Oct 03, 2017Guide
QoS was never enabled to begin with.
