DESMO1198s
Oct 01, 2017Guide
R7000 SLOWS WAY DOWN with Firmware 1.0.9.10 went back to 1.0.9.6 problem solved. Hold off on update
Just updated the Firmware of my R7000 to the latest 1.0.9.10 from 1.0.9.6 and it cut my download speed from 178MBps on all my devices ( MacBook Pro, iPhone7, iPad Air2) to less than 80MBps. Full pow...
DESMO1198s
Oct 02, 2017Guide
Ok so I put almsot 2 hrs into this and heres the curent status. For whatever reason I was not able to update the QoS datbase until after I did a full factory reset. The option to do so simply wasnt there. I will say though that after the resest I was only able to see the "update" option for the QoS Database when switching the QoS feature on and off. Also I did multiple speed test durign the process both wired and wirelessly on my laptop, phone and tablet. SO When I did the factory reset it did roll the router to an older firmware (forgive me as I cant rember what version it was, but it did instantly update itself to the 1.0.9.10 right away, then I updated the QoS Database. When connected via ethernet cable (laptop only) my speed was consistleny over 170 (im paying for 150), no matter the firmware version or QoS Database. With just the New Firmare after factory reset My laptop was the only one that wirelessly would consistenlty get to 170-175. But iPhone7 and iPad Air2 only got to 90-100. This is an improvement from the initial update. After the QoS update I was now getting a consistent 150-155 on both phone and tablet. Agian this is an improvement. So just as a gee wiz I reloaded 1.0.9.6 and just like that all devices were back gettign consistenly over 175 and up. QoS database is updated. So for now I believe updatign the QoS Database was very helpfull when working with the newest Firmware. But somethiing is still not correct. So will give it some time before I try 1.0.9.10. agian.
