DESMO1198s
Oct 01, 2017Guide
R7000 SLOWS WAY DOWN with Firmware 1.0.9.10 went back to 1.0.9.6 problem solved. Hold off on update
Just updated the Firmware of my R7000 to the latest 1.0.9.10 from 1.0.9.6 and it cut my download speed from 178MBps on all my devices ( MacBook Pro, iPhone7, iPad Air2) to less than 80MBps. Full pow...
compaholic
Oct 31, 2017Aspirant
Having the same problem with V1.0.9.10 and V1.0.9.12 the Wifi slows down to 43-44Mbps max. It doesnt matter what the Wifi device is, Samsung Galaxy S7, Galaxy S8+, iPad Air 1, and Air 2 in the house all max at that speed.
When I downgrade back to V1.0.9.6_1.2.19 the download speeds max 215-230Mbps (I have the 200Mbps plan with Comcast)
I do not use the QoS feature, it was disabled before the updates.
Access Control is not enabled.
What gives?
