WireEDMguy
Jun 16, 2018Initiate
R7000 software upgrade kills HP Officejet 8100 wifi print connection
My R7000 router and my HP wifi printer have been working great together since 2014. I upgraded my router's firmware. Didn't have a print job for about a week. Went I sent something to the printer it ...
- Jun 16, 2018
A couple of things here...
- Are you on Windows 10 and did you get an update for it since the last time you printed?
- Do you get ANY error messages and if so what were they?
- Do you see the printer connected on the Router?
- I'm assuming the printer has a screen and a Network Option, what does that show, IP Address, connected or not?
- Had you tried using the HP tools, such as the HP Print and Scan Doctor? What happens when you do?
- I assume you meant the USB cable connected to the R7000 USB port? Does it show on the USB tab?
- Can you try connecting to a USB port on a PC and see if the printer work?
- Did you RESET the router after installing the last firmware?
- Have you tried re-installing the older firmware to test and see if the printer works there?
IrvSp
Jun 16, 2018Master
antinode
Jun 16, 2018Guru
> I tried a reinstall of the printer using the usb cable and it still
> can't find the printer.
I assumed that this was a USB connection between the printer and the
computer, but the description was ambiguous.
