Scii264
May 23, 2022Aspirant
R7000 Solid Amber Power LED
Today, I upgraded to an AX router and replaced my R7000. The R7000 has been working great, I just got a free AX router and wanted to mess around with Wifi 6. I decided I would use the R7000 as a repe...
May 23, 2022Guru - Experienced User
A 10 second press and release should be all that's needed on the reset button. If you don't get a 192.168.1.something with a wired PC connected, something has gone bad.
I'd check in to another power adapter block to see if this could be an issue. If after this, the router doesn't come to ready after a reset press, I guess it's a goner.
- wcalifasMay 24, 2022Prodigy
I agree could be a bad power adapter, or corrupt firmware.
