junglesim
Jan 12, 2023Star
R7000. Some devices losing connection but not all
Hi, I apologise if this issued is covered elsewhere. On a daily basis, several of my home devices lose connection to the internet while still connected to My R7000 (firmware V1.0.11.136_10.2.120). S...
Jan 12, 2023Guru - Experienced User
What modem/gateway is the router connected to?
junglesim
Jan 12, 2023Star
Hi plemans. Thank you for your reply. It is connected to a bog standard cable modem from my ISP. Perhaps I am being naive but I discounted the modem as being the issue as it is a passthrough and I believe all the DNS activity happens in the router.
- plemansJan 12, 2023Guru - Experienced User
No idea what model a "bog standard modem" is but they can be important. Some bridge modes are poorly implemented or not even a proper bridge mode at all.
Its why sometimes we'll recommend leaving a ISP supplied modem/router in router mode, disable its wifi, and then either put the netgears IP address into its DMZ or run the netgear in access point mode.
- junglesimJan 12, 2023Star
It's a Virgin Media Super Hub 2 that I have had for an age (I doubt this would mean much too you so I omitted it). I will certainly give what you say a whirl, thanks. I am a tad sceptical that it'll work as I've had the modem in modem-mode connected to my R7000 for years and it worked flawlessly.
Ahh the virgin hubs.
It wouldn't be the first time I've seen one of those updated poorly and fubar everything.
Give it a shot, maybe it'll work.
If not, how many devices do you have the the R7000?
its getting a little older of a device having been released in 2013.
