Retired_Member
Jun 26, 2021R7000 Spectrum Modem Compatibility
Spectrum recently upgraded my modem and I had used an older version for years. I started having intermittent problems losing TV and internet so they came out and replaced the modem. The problem persi...
Jun 26, 2021Guru - Experienced User
The R7000 has been a firmware issue for years. Some people have great luck on the newer firmware, others downgrade to the 1.0.9.42 version.
I'd be happy you've got it working decently again :)
Retired_Member
Jun 26, 2021In case I run into problems again, is there a newer Netgear router without the problem?
