Retired_Member
Jun 26, 2021R7000 Spectrum Modem Compatibility
Spectrum recently upgraded my modem and I had used an older version for years. I started having intermittent problems losing TV and internet so they came out and replaced the modem. The problem persi...
Retired_Member
Jun 26, 2021In case I run into problems again, is there a newer Netgear router without the problem?
Jun 26, 2021Guru - Experienced User
There's a lot of newer routers. The R7000 is 8 years old (released in 2013).
So you've got plenty of upgrade potentials for newer devices :)
