splitty_
May 23, 2017Aspirant
R7000 (Speed is less than half compared to Verizon router)
Recently upgraded to the gigabit connection offered by Verizon fios. I been using the R7000 as my primary router and using the fios(modem/router combo) as more of a modem as I turned off the wireless ...
- May 23, 2017So turn off AP mode and run just router mode as well as connecting with LAN instead of the WAN port? Just to clarify. Thanks
TheEther
May 23, 2017Guru
AP mode disables hardware acceleration. Try connecting the R7000 to the network through one of its LAN ports. This will bypass the slow path between the WAN and LAN ports. IOW, don't use the WAN port. You may lose the ability to log into the R7000. Just reconnect the WAN port when you need to log in.
