splitty_'s avatar
splitty_
R7000 (Speed is less than half compared to Verizon router)
Recently upgraded to the gigabit connection offered by Verizon fios. I been using the R7000 as my primary router and using the fios(modem/router combo) as more of a modem as I turned off the wireless ...
  • splitty_'s avatar
    May 23, 2017
    So turn off AP mode and run just router mode as well as connecting with LAN instead of the WAN port? Just to clarify. Thanks
