splitty_
May 23, 2017Aspirant
R7000 (Speed is less than half compared to Verizon router)
Recently upgraded to the gigabit connection offered by Verizon fios. I been using the R7000 as my primary router and using the fios(modem/router combo) as more of a modem as I turned off the wireless ...
- May 23, 2017So turn off AP mode and run just router mode as well as connecting with LAN instead of the WAN port? Just to clarify. Thanks
TheEther
May 25, 2017Guru
Glad you got it working. To answer your prior question, running it in router mode will also work but you have to disable the DHCP server. There's no need to do this; as you have already seen, it also works in AP mode.
JMRtitan
Jul 28, 2017Aspirant
I'm also having the same issue just got Verizon fios gigabit internet an having that same problem can you please explain to me what you did to fix it thank you
- splitty_Jul 28, 2017AspirantHi, I just plugged the cable from my Verizon router into the LAN port on the Netgear instead of the yellow internet (WAN) port. Then I did a speed test and got 850+Mbps down
