IronGold
Jul 27, 2023Aspirant
R7000 speedcap Xbox Series X over ethernet (Google Fiber)
Hello All, Looking for some help. I've recently switched to Google Fiber and have run into an issue with the Xbox series X. Its speed seems to be capped at ~150MB down when connected through ...
Kitsap
Jul 27, 2023Master
Congratulations on a well-documented and thorough post.
In the user interface under the Advanced Tab -> Internet Port -> Show Statistics it will show your individual port status. Each of your ports should show 1000M/Full. Do they?
You have made many hardware configuration and connection changes. After you made the changes, did you power down your entire network and restart it in sequence? By power down, I mean pull the power cord on each device. Restarting in sequence would be to power up the ONT and give it ample time to connect and stabilize. Followed by your router and give it ample time to connect and stabilize. Then your X box, power up and stabilize before testing.
Communication protocols between devices are established when they are first powered up and connected. After connection changes if you do not restart the devices, some of the protocols from the previously connected device can still be in place and not work appropriately.
michaelkenward
Jul 28, 2023Guru - Experienced User
That is also one reason why it can help to reset a router when you change the Internet service.
If nothing else, go into the router's Internet settings and take it through the setup wizard.
