IronGold
Jul 27, 2023Aspirant
R7000 speedcap Xbox Series X over ethernet (Google Fiber)
Hello All, Looking for some help. I've recently switched to Google Fiber and have run into an issue with the Xbox series X. Its speed seems to be capped at ~150MB down when connected through ...
IronGold
Jul 28, 2023Aspirant
Congratulations on a well-documented and thorough post.
Thank you! I promise I did look for a solution before posting.
In the user interface under the Advanced Tab -> Internet Port -> Show Statistics it will show your individual port status. Each of your ports should show 1000M/Full. Do they?
They Do:
- LAN1 = Xbox
- LAN2 = Desktop
After you made the changes, did you power down your entire network and restart it in sequence?
I repeated this step just in case. But I'm seeing the same results (desktop ~700M down, Xbox ~130M down)
I had performed a factory reset of the router when we were setting the system up post Fiber install as well.
I assume that'll revert the firmware version if I do it again, and It's annoying to reset everything. But I'm willing to try.
michaelkenward
Jul 28, 2023Guru - Experienced User
The Xbox is a constant source of issues around here. It is sometimes down to the settings on the Xbox itself.
Here's one search that you might not have come across:
Search - NETGEAR Communities – xbox nat
